Activity › Forums › Apple Final Cut Pro Legacy › text pixelated
text pixelated
Posted by Rui Carvalho on March 7, 2010 at 12:30 pmwhy when i use the generator of text in final cut and then export the movie to see on television the text is always at the edges pixelated???
PPX
Rui Carvalho replied 16 years, 2 months ago 3 Members · 8 Replies -
David Roth weiss
March 7, 2010 at 3:25 pm1. Use Boris Title 3D instead of the standard text tool. It comes with FCP, not an add on.
2. When your done editing, go to Sequence>>Settings and change the compressor to DV50, then re-render the entire timeline.
David Roth Weiss
Director/Editor/Colorist
David Weiss Productions, Inc.
Los AngelesPOST-PRODUCTION WITHOUT THE USUAL INSANITY ™
A forum host of Creative COW’s Apple Final Cut Pro, Business & Marketing, Indie Film & Documentary, and Film History & Appreciations forums.
Arnie Schlissel
March 7, 2010 at 5:22 pmYours is the 3rd posting this weekend to ask why your video quality doesn’t look good. the answers are always the same:
1- You’re not working in a high quality codec
2- You’re not monitoring your picture properly
3- Both of the aboveArnie
Post production is not an afterthought!
https://www.arniepix.com/ -
Rui Carvalho
March 7, 2010 at 6:31 pmwhat is the appropriate codec for high quality? pro res hq? i have a sequence already edited with another codec, change the codec will work? or have to re-edit everything from the beginning with the correct codec? tanks a lot
PPX
David Roth weiss
March 7, 2010 at 7:27 pmI told you exactly how to do the proper steps in #2 above. If I meant for you to use ProRes HQ I would have told you to use it. Just follow the instructions.
David Roth Weiss
Rui Carvalho
March 8, 2010 at 9:41 amok sorry..
but i dont have a codev named dv 50 i just have dvcpro50 what shoud i do?? tanksPPX
David Roth weiss
March 8, 2010 at 5:14 pm[rui carvalho] “i just have dvcpro50 what shoud i do?? “
Use DVCPro50. Apple had it mislabeled as DV50 for nearly ten years, I guess they’ve finally fixed it.
David Roth Weiss
EPK Colorist – UP IN THE AIR – nominated for six academy awards
Rui Carvalho
March 8, 2010 at 10:29 pmi have alredy try and doesnt work any ideia what could be?? tanks a lot for the help
PPX
