Activity › Forums › Maxon Cinema 4D › Text/ object texturing
  • Text/ object texturing
    Posted by Fabian Bosman on November 16, 2010 at 4:43 pm
    Hi guys,
    I’m expirimenting with spline masks and I want to create a text with an orange color on the inside of the text.
    So when you extrude the text/spline you would see the inside color.
    My question is:
    Is it possible to create something like this?
    (only the first scene, the orange color inside)
    https://www.vimeo.com/14419594
    Please answer my question and help me and you’re a life saver 😛
    This happens because the functionality/content marked as “Vimeo framework” uses cookies that you choosed to keep disabled. In order to view this content or use this functionality, please enable cookies: click here to open your cookie preferences.
    Fabian Bosman replied 15 years, 10 months ago 2 Members · 4 Replies
  • Randy Johnson
    November 16, 2010 at 6:32 pm
  • Fabian Bosman
    November 16, 2010 at 8:12 pm
    Thanks for your answer, i can’t get the result that i want, is there a way to spline mask a text and maybe duplicate the text and make it a bit smaller and than it looks like the inside of the letter???
    I can’t get the result yet, but i think it is possible, I mean you can add colors to editable polygons but can i add colors without making it editable?
    Greetz,
    Fabian
  • Randy Johnson
    November 17, 2010 at 8:04 am
    For texturing parametric objects like extrude and sweep and all the primitives you just type in the selection place: C1 for cap one, C2 for cap two, R1 for the the rounding, R2 …. I think this is in the user manual for sweep nurbs.
    For the example you showed I would jest set up multiple Sweep Nurbs and animate them using different cap settings to kinda extrude showing the next sweep. Hope that makes sense.
    /Randy
  • Fabian Bosman
    November 17, 2010 at 9:03 am
    Hi Randy,
    thanks for your comment, i hope your tip will work.
    I’ve asked the maker of the animation (Esteban) to give some tips and he explaned what he did.
    He talked about the boolean effect that he put the spline into a boolean with the text that you want to put an inside color on it (i dont know if this is correct english but i hope you understand what i mean).
    greetz,
    Fabian
