Activity › Forums › Adobe After Effects › Text morphing/character changing plugin/preset in a single layer
  • Text morphing/character changing plugin/preset in a single layer
    Posted by Diana Artichoke on October 30, 2015 at 1:40 am
    Hi everyone,
    I was wondering whether anyone could suggest a way/expression/plugin/preset to change text characters from one to another. I know you can change the source text with keyframes, but I need them t morph into each other, and that usually involves making different layers. Any chance to do it all in one layer?
    Thank you!
    John Cuevas replied 10 years, 11 months ago 3 Members · 2 Replies
  • Ashish Gupta
    October 30, 2015 at 8:46 am
    You need to create masks or shapes of the characters you want to morph(you can do that simply by right clicking on the text layer and selecting create shapes from text). Then you have to copy and paste one mask or shape path keyframe at a time,from one character to the other. The process involves a lot of tweaking after this to create smooth motion.
    Ashish Gupta
    Motiongraphics artist and 3d generalist
    aashi.29nov@gmail.com
  • John Cuevas
    October 30, 2015 at 4:16 pm
    There isn’t a plugin/preset that’s going to do it. Truthfully, this is where you earn your bucks, cause depending on the amount of text, it can be a pretty time consuming process.
    Google Results “morph text after effects tutorial”
    All the tutorials use basically the same concept, this one is pretty good.
    https://www.youtube.com/watch?v=ni24lqXRveU
    Johnny Cuevas, Editor
    ThinkCK
    “I have not failed 700 times. I have succeeded in proving that those 700 ways will not work. When I have eliminated the ways that will not work, I will find the way that will work.”
    —THOMAS EDISON on inventing the light bulb.
