Activity Forums VEGAS Pro Text Media doesn’t left justify
  • Text Media doesn’t left justify
    Posted by Brian Bischof on March 23, 2013 at 6:53 am
    Ok, I’m getting really frustrated that Google can’t help me with the problems I’m having tonight. So i registered here and I’m posting three separate questions hoping someone can point me in the right direction. Here is number 1:
    I’m trying to create the “PowerPoint” affect where the first line of text appears, then the second line appears, then the third, etc. I inserted Text Media, made it left justified, typed in my text. Next I created a new keypoint, typed in my 2nd line of text (which is longer). Lastly I repeated for the third line of text.
    The problem is that since the first line of text is the shortest, it changes position on the screen when the second line appears. It’s as if SV says, “Oh, this line is longer, I better make more room and shift everything over”. How do I prevent this? I want the text to stay in the same left justified position the entire time.
    Brian
    Brian Bischof replied 13 years, 5 months ago 2 Members · 2 Replies
  • Edward Troxel
    March 25, 2013 at 7:53 pm
    Either use Legacy Text or NewBlue Titler. Both will do what you are wanting. In fact, You can just type in the text and the NewBlue titler can type it on for you.
    Edward Troxel
  • Brian Bischof
    March 29, 2013 at 8:19 am
    That did it again. Thanks!
