Activity Forums Zaxwerks text mapping
  • text mapping
    Posted by Doug on August 31, 2005 at 1:23 pm
    I have a ribbon that has a movie mapped to it. What i would like to do now, is add a reflection of text that flows across the ribbon as the camera pans acros. I have tried many diffeent setting with no luck. The text is a grayscale targa file. Can anyone point me in the right direction?
    Hail the Cow!
    Doug
    Doug replied 21 years ago 2 Members · 2 Replies
  • Zax Dow
    August 31, 2005 at 11:28 pm
    Hi Doug,
    This isn’t a particularly 3-D way of doing it, but here’s a technique which may work for you.
    – Take the image that is to be the reflection and flip it vertically
    – Then use the alpha of the ribbon as a track matte.
    – If you need to distort the image so it follows the shape of the ribbon you can use AE’s Mesh Warp feature set to a low number of Rows and Columns (such as 1 x 3)
    – Then blend a little of the image back onto the ribbon adjusting opacity to taste.
    Zax
  • Doug
    September 1, 2005 at 3:52 am
    Gracias,
    I shall give it a try.
    Hail the Cow!
    Doug
