Activity Forums Adobe After Effects Text losing resolution when layer becomes a 3D layer
  • Text losing resolution when layer becomes a 3D layer
    Posted by Mike Barber on July 17, 2011 at 4:55 pm
    I’m doing some motion graphics work and am using After Effects instead of Motion (currently making the transition from Apple FCS to Adobe CS). I am noticing that my text layers are losing resolution—become soft and fuzzy—when I enable their layers as 3D layers. What’s going on?
    The top text has 3D Layer enabled, the bottom does not. That is the only difference.
    The camera does not have Depth of Field enabled. Resolution is set to Full. OpenGL is enabled.
    I’m using After Effects CS5 on a Quad-Core 2.8GHz Mac Pro with 8 GB RAM and NVIDIA GeForce 8800 GT graphics card, running OS X 10.6.8.
    Eric Smith replied 13 years, 11 months ago 5 Members · 6 Replies
  • Roland R. kahlenberg
    July 18, 2011 at 4:23 am
    Take a look at it without OpenGL – just a wild guess but worth a shout nonetheless.
    Cheers
    RoRK
    Intensive AE & Mocha Training in Asia.
  • Mike Barber
    July 19, 2011 at 3:23 am
    [Roland R. Kahlenberg] “Take a look at it without OpenGL”
    no improvement, sad to say, which is really frustrating. I know After Effects is a serious, professional tool… this must be user error, right? Animating text (kinetic text with camera) was such a simple no-brainer in Motion, but here I am getting these little frustrations about the quality of my output.
  • Michael Szalapski
    July 19, 2011 at 2:56 pm
    Have you updated your AE to the latest version? 10.0.2
    That seems weird.
    I don’t have an issue like that here. Have you tried that with other fonts on the off chance that it’s something weird with a non-pro font?
    – The Great Szalam
    (The ‘Great’ stands for ‘Not So Great, in fact, Extremely Humble’)
  • Mike Barber
    July 19, 2011 at 3:21 pm
    I’m pretty sure it is updated to 10.0.2, I’ll check later this evening and try with different font. I used the same one (CheltPress) in a similar Motion project without this happening,, so it does strike me as odd.
  • Ryan Maloney
    July 23, 2011 at 9:11 pm
    i run into this issue often. i pre-compose my text and then toggle the little sun icon (forget the name of the setting). make sure your text layer in side your pre-comp is a 3d layer too
    ryan
    https://www.medialuv.com
  • Eric Smith
    September 13, 2012 at 11:17 pm
    I am having the same problem. Was this ever resolved? Would be great if someone could pick it up.
    I tried open GL, preserve resolution when nested …
    Much Thanks
