Activity › Forums › Adobe After Effects Expressions › Text list of timestamps for multiple clips
  • Trent Armstrong
    February 3, 2021 at 5:32 pm
    I’m not sure if this is exactly what you’re looking for, but you can put a Text layer at the bottom of your layer stack and put this expression in the sourceText field:
    list = [];
    times = [];
    for (i=1; i<=thisComp.numLayers – 1; i++) {
    list.push(“\r” + thisComp.layer(i).name + ” — ” + timeToTimecode(thisComp.layer(i).inPoint))
    list;
    If you need to pull that list out, you can select the sourceText and run Convert Animation to Keyframes. That will bake the text into the layer and make it editable.
  • John Bartmann
    February 4, 2021 at 12:52 pm
    Thank you Trent
