Activity Forums Adobe After Effects Text layers from InDesign -> Photoshop (to be used in AE)?
  • Text layers from InDesign -> Photoshop (to be used in AE)?
    Posted by Adam Lewen on April 22, 2019 at 10:15 am
    Hi again!
    Is there a workaround to keep text layers from Indesign into Photoshop? to be later used in AE?
    Thanks so much for any tip!
    Adam Lewen replied 7 years, 4 months ago 2 Members · 2 Replies
  • Kalleheikki Kannisto
    April 22, 2019 at 5:31 pm
    You can do it if you add Illustrator to the mix.
    1) Export from InDesign as PDF
    2) Open PDF in Illustrator, export as Photoshop in such color format that allows exporting with layers and preserving text editability, (generally CMYK)
    3) Open in Photoshop, convert to RGB, retaining layers, save
    4) Import to AE (I guess you already know the required settings and what to do from here)
    Senior Graphic Designer
  • Adam Lewen
    April 22, 2019 at 7:01 pm
    Wow…
    what a round-trip… for a couple of dozen files with a lot of titles…
    Oy.
    Some one told me there might be somekind of script for that. I will try digging, although im not on the Indisign side…
    Thanks again Kalleheikki!
