Activity Forums Adobe After Effects Expressions Text layer looking at slider with an addition and keeping to two decimal places
  • Text layer looking at slider with an addition and keeping to two decimal places
    Posted by Ashley Aslett on September 17, 2021 at 8:21 pm
    I have a text layer looking at a slider control, I want to add 2 to the number that it is looking at. I guess something like this:
    thisComp.layer(“% P&L”).effect(“Slider Control”)(“Slider”)+2
    However I want to keep the resulting number to 2 decimal places, I know you can use the following but not sure where to add this into the above expression as keep getting errors?
    .value.toFixed(2)
    Any help greatly appreciated!
    Ashley Aslett replied 4 years, 10 months ago 3 Members · 9 Replies
  • 9 Replies
  • Dan Ebberts
    September 17, 2021 at 8:27 pm
    Something like this should work:
    (thisComp.layer("% P&L").effect("Slider Control")("Slider")+2).toFixed(2)
  • Fabrice Leconte
    September 17, 2021 at 8:28 pm
    Hello,
    Try something like this:
    (thisComp.layer('% P&L').effect('Slider Control')('Slider')+2).toFixed(2);
  • Ashley Aslett
    September 17, 2021 at 8:30 pm
    Dan you are an absolute hero, saved my bacon again!
    Fabrice thanks also for the super swift reply.
    Sending huge thanks both your ways!
  • Ashley Aslett
    September 17, 2021 at 8:58 pm
    Last one, I promise!!
    Can either of you help with the below:
    “$”+ num = (thisComp.layer(“% P&L”).effect(“Slider Control”)(“Slider”)*10000000).toFixed(0);
    function addCommas(x) {
    return x.toString().replace(/\B(?=(\d{3})+(?!\d))/g, “,”);
    addCommas(num)
    Basically I have a text layer looking at a slider, multiplying that number by 10,000,000, keeping it to two decimal places and adding in commas….however I want a dollar sign at the start.
    Searching around I came up with the above but the $ symbol is not showing.
    As always your help is appreciated.
  • Ashley Aslett
    September 17, 2021 at 9:03 pm
    All good chaps, just figured it out by switching it around!…
    num = “$”+ (thisComp.layer(“% P&L”).effect(“Slider Control”)(“Slider”)*10000000).toFixed(0);
    addCommas(num)
  • Fabrice Leconte
    September 17, 2021 at 10:44 pm
    Yes or you can use Intl.NumberFormat
    Intl.NumberFormat('en-US', {
    style: 'currency',
    currency: 'USD',
    minimumFractionDigits: 0
    }).format((thisComp.layer('% P&L').effect('Slider Control')(1) * 10000000));
  • Ashley Aslett
    October 13, 2021 at 3:14 pm
    Hey guys, one more question on the above!
    When inputting the following number on the below script -0.1742331 the output is $-1,742,331. Is there a way to change the script so the output is -$1,742,331…the minus symbol comes before the dollar sign rather than after it?
    addCommas(num)
    As always any help would be super appreciated!
  • Dan Ebberts
    October 13, 2021 at 7:18 pm
    Try it this way:
    n = thisComp.layer("% P&L").effect("Slider Control")("Slider");
    sign = n < 0 ? "-" : "";
    num = sign + "$"+ (Math.abs(n)*10000000).toFixed(0);
    return x.toString().replace(/\B(?=(\d{3})+(?!\d))/g, ",");
    addCommas(num)
  • Ashley Aslett
    October 17, 2021 at 3:06 pm
    As always, worked perfectly!
    Your help is super appreciated! Thanks
