Activity Forums Adobe After Effects Text layer disappears when an effect is applied
  • Text layer disappears when an effect is applied
    Posted by Charlie Nancy on May 20, 2014 at 12:34 am
    I have a text layer which is motion tracked to a null object, and is also attached to a track matte mask. As soon as a drag a blur onto the text, even if the blur is still set at zero, the text completely disappears. Is this a bug or am I doing something wrong?
    Evan Robinson replied 12 years, 4 months ago 2 Members · 3 Replies
  • Evan Robinson
    May 20, 2014 at 1:38 am
    Did you try pre-composing the text layer?
    E. Robinson
  • Charlie Nancy
    May 20, 2014 at 2:31 am
    I didn’t no – that solved the problem! Thank you.
  • Evan Robinson
    May 20, 2014 at 4:03 am
    No problem, glad it worked.
    E. Robinson
