Activity Forums Adobe After Effects Text is jittering even when no values are changing
  • Text is jittering even when no values are changing
    Posted by David Cabestany on May 1, 2013 at 6:17 pm
    I have this two text layers that are following a camera that I imported from Cinema 4D, almost at the end the text starts to jitter and it does it for the last 10 frames. I thought it was my camera, since I had tweaked the beginning of it, so I reimported it, but it’s still there.
    I deleted the keyframes and added a loopOut Continue expression, the camera moves correctly, but the text is still jittering, what’s weirder, it’s the actual pixels jumping instead of the object, they are jumping out of their box, please the attached video to see what I mean.
    I restarted my machine, reset the PRAM and repaired permissions, all I got is the issue appearing inside After Effects, whereas before I could only see it after rendering.
    Any help will be greatly appreciated.
    jittery text
    David Cabestany replied 13 years ago 1 Member · 0 Replies
  • 0 Replies
