Activity Forums Adobe After Effects text is jagged in final render..
  • text is jagged in final render..
    Posted by Galactus on October 28, 2005 at 5:07 pm
    can anyone tell me if there is a special codec I should use for Avid 720×480 dv output of a simple xtreme blurred text animation??
    animation comes in all blurred, snaps into focus and scales up. final frame of the scaled up text is 100%, yet when viewed in the Avid..the text is jagged and alias.
    any thoughts or suggestions?
    thanks much!
    Galactus replied 20 years, 10 months ago 3 Members · 4 Replies
  • Ben G unguren
    October 28, 2005 at 5:09 pm
    This is kind of obvious, but just in case…. Are you choosing “Best Settings” in your Render Queue? Maybe it’s stuck at “Current Settings” and your text isn’t already anti-aliased.
  • Galactus
    October 28, 2005 at 5:17 pm
    yeah sorry…should have stated that;
    definetly set to best quality and full resolution in the final render. looks great while test rendering in AE. but when the quicktime mov file is pulled into Avid…it looks jagged. no crispyness from AE.
    thanks!
  • Steve Roberts
    October 28, 2005 at 5:37 pm
    Hmmm … did you render with an alpha channel? Avid likes “straight alpha”.
    Steve
  • Galactus
    October 28, 2005 at 5:45 pm
    I was rendering a separate alpha mov..but will try your straight alpha suggestion Steve. thanks
