Activity Forums Apple Final Cut Pro Legacy Text is blurry
  • Posted by Drew Conner on April 6, 2005 at 6:29 am
    I am creating my text useing the simple text generator in final cut pro. I was trying to create a music video text layover that goes in the bottom left of the screen. After i added the text generator the green bar appeared over the top of the text telling me it needed to be rendered. When i viewed the text frame by frame with out it being rendered the text looks very crisp and clear. After rendering the text it becomes blurry and almost unreadable. I’ve never had this problem before and im totally stumped. Even when i bring text in from livetype it looks blurry as well.
    Geoff Hug replied 17 years, 9 months ago 7 Members · 6 Replies
  • Christoph Baaden
    April 6, 2005 at 6:52 am
    Make sure your render settings are set to high.
    Also, check that your text positioned on an even number on the Y-axis.
    Christoph
  • Max Frank
    April 6, 2005 at 11:38 am
    They say you should make sure you view your video on an actual NTSC monitor, too.
    That notwithstanding, there are known issues with FCP text.
    Wayne
    2DP G5, 3.5GB RAM, FCP HD
  • Bogdan
    April 6, 2005 at 4:06 pm
    About the even line on the Y axis… a quick question…
    I have experienced this with text, too – but even when I crop my movies to make it 16:9 (on a 4;3 monitor of course) and I do some adjustments to the image (I put it lower or higher), sometimes the image gets blurry. Now I understand that if it “falls” on some lines it gets blurry – how do you make sure that even if you move it up and down it stays clean? It has to do with odd/even lines on the Y axis? It’s just a matter of chenging the crop parameters to a odd line?
  • Kevin Monahan
    April 6, 2005 at 5:14 pm
    Next time, please do a search of the forum. We see this problem every day.
    Make sure to:
  • Paloma Polo
    January 20, 2008 at 8:05 pm
    I am sorry to sound so stupid but where are the odd/even lines on the Y axis located? I have a problem with blurry text and I would like to try that, but I don
  • Geoff Hug
    December 11, 2008 at 4:00 pm
    Could someone please explain how to locate the Y axis (i.e. make it visible) and which line specifically the text should be lined up on?
    I am rendering special features for feature film DVD and the blurry text looks awful.
    Many thanks.
    Geoff
