Activity › Forums › Apple Final Cut Pro Legacy › Text in Final Cut
  • Text in Final Cut
    Posted by Kevin Hilton on October 2, 2012 at 11:30 pm
    I edited a movie in final cut its about an hour long and has a lot of text in it i just found a new font i want to use is there an easier way to change all of the fonts at once, than just doing each one individually?
    Bouke Vahl replied 13 years, 12 months ago 4 Members · 3 Replies
  • Shane Ross
    October 2, 2012 at 11:45 pm
    I wish. Sorry, alas, no.
    Shane
    Little Frog Post
  • Rob Tinworth
    October 3, 2012 at 1:53 am
    If you just used the FCP text generator (not sure whether this works with Boris 3D), this is a really handy tool for subtitles:
    https://www.spherico.de/filmtools/TitleExchange/
    It’s a little fiddly, but essentially you export an xml of a timeline with a single sample title in the font+style that you want to change everything to. With that xml you create a template in Title Exchange Pro.
    Then export all your subtitles on one track as an xml, and use TEP to convert the xml, to an xml, but using the template you created. That will change the font – and any of the parameters in the text generator – of all the subtitles. Then reimport the new xml into FCP.
    It’s a real timesaver.
    Rob Tinworth
    http://www.1021.tv
  • Bouke Vahl
    October 3, 2012 at 3:33 pm
    Or, just export to XML, do a search / replace in a text editor and be done with it.
    Should not take more than 2 minutes…
    Bouke
    https://www.videotoolshed.com/
    smart tools for video pros
