Activity Forums Adobe After Effects Text in 3d space
  • Text in 3d space
    Posted by Joeythedog on August 6, 2005 at 7:47 pm
    I draw a semi- circle line path(mask) with the pen tool. Create a line of text.
    Transferr text to mask (path). Go to 3d. Rotate x axis 90 degrees. Now text is flat. Just the edge is seen. How do I get the text to stand up off the rotated path so you can see the text face when it travels the semi- circle mask from distant to fore.
    Aharon Rabinowitz replied 21 years, 1 month ago 2 Members · 1 Reply
  • Aharon Rabinowitz
    August 7, 2005 at 4:37 am
    set the text’s X orientation to 90 or -90. It’s under the rotation property.
    Aharon Rabinowitz
    aharon(AT)yahoo(DOT)com
    http://www.allbetsareoff.com
    Creative Cow Master Series DVD
    particleIllusion Fusion Volume 1
    available @ http://www.pIllusionFusion.com
