Activity › Forums › VEGAS Pro › TEXT has jagged edges and appears to “vibrate” on screen.
  • TEXT has jagged edges and appears to “vibrate” on screen.
    Posted by Mark Krueger on December 13, 2011 at 9:07 am
    I have some text made with vegas 10. small font size (20) used in a credit roll situation and also a static title.
    The title looks good on the preview window, but looks very jagged and appears to have a glowing vibrate to each letter. The font color is white and the background is black.
    Any Ideas as to what is going on here?
    Steve Rhoden replied 14 years, 9 months ago 3 Members · 7 Replies
  • 7 Replies
  • Steve Rhoden
    December 13, 2011 at 1:07 pm
    What resolution video are you working on and whats the format
    you render it out as?
    (Doubling the fonts resolution if working in 720×480 media
    helps a lot)
    Steve Rhoden
    (Cow Leader)
    Film Maker
    Filmex Creative Media.
    1-876-832-4956
    https://filmex-creative-media.blogspot.com/
  • Mark Krueger
    December 13, 2011 at 3:00 pm
    Steve, Are you referring to the generated media’s frame size?
    My rendered project is a 720 x 480.
    Mark
  • Mike Kujbida
    December 13, 2011 at 3:28 pm
    I’m not Steve but the answer to that question is yes.
    Change 720 x 480 to 1440 x 960.
    You will notice an improvement in the quality of your text.
  • Mike Kujbida
    December 13, 2011 at 3:30 pm
    I forgot to mention that your whites shouldn’t go over 235-235-235 and your blacks shouldn’t go below 16-16-16.
    This keep things within legal limits (16-235) and should help.
  • Mark Krueger
    December 13, 2011 at 3:36 pm
    Mike where do I set these black and white levels
  • Mike Kujbida
    December 13, 2011 at 4:15 pm
    Mark, switch to the Properties and Effects tabs and set the levels there.
    Changing the Outline and Shadow settings may be overkill but it only takes a moment and then everything is legal.
  • Steve Rhoden
    December 13, 2011 at 4:16 pm
    Now with the advices you are given, you should be ok.
    Steve Rhoden
    (Cow Leader)
    Film Maker
    1-876-832-4956
