Activity Forums VEGAS Pro Text generator doesn’t preserve formatting
  • Text generator doesn’t preserve formatting
    Posted by Bob Mark on November 16, 2009 at 6:53 pm
    I’m trying to cut and paste French captions into Vegas, but I lose formatting on the the French symbol (MC) for Trade Mark. I can paste regular Trade Mark symbols (TM) and keep the formatting (size and placement), but the French just changes to full size letters. Any ideas on this? Thanks.
    Bob Mark replied 16 years, 10 months ago 2 Members · 2 Replies
  • Graham Bernard
    November 17, 2009 at 6:44 am
    Eh, nasty . .
    As you have discovered the TM or ™ is an actual MS symbol – it isn’t a set of letters at all. Now, whatever you are bringing into Vegas would appear NOT to be an extended Character Symbol, from the MS character set/s, but it IS in itself, possibly, a SUPERSCRIPT set of 2 letters – “M” and “C”. You have proved this by noticing that the formatting is not retained. This to me proves that the MC is in itself, NOT a character symbol. OK . . . My advice would be to use ProTypeTitler, you can do a SUPERSCRIPT look-a-like bit within the same text Event box by manually adding a smaller upper box, or, horrible this, use the standard SONY TEXT using 2 tracks JUST for the MC to appear in the correct size and position – nasty! Mind you, once you have this setup it is only a need for this to be copy/pasted to the region you’re doing? Does that make sense?
    So, to recap, TM is not a set of 2 characters but a symbol, and hence its perceived ability to “retain” its appearance of superscript formatting – which it isn’t! – and to either use 2 Tracks or PTT.
    Sorry, but this is the best I can come up with? And I have done some quick INTERNET research on this and I truly cannot find a “MC” in the format/symbol you want.
    Grazie
  • Bob Mark
    November 17, 2009 at 10:00 pm
    Thank you for your reply. I think you are right. Luckily, the accent marks came in as they should or I would have been in big trouble. The French symbols for trademark and registered di not. Lucky, the Spanish was the same as English. I have not been able to get the hang of the Pro Type Titler. I come from using Inscriber CG and that Sony titler is not friendly to me. I wound up doing the second workaround you mentioned. Yes, it was very tedious! Thanks for the info!
    Bob
