Activity Forums Apple Motion Text exported from Motion comes out garbled
  • Text exported from Motion comes out garbled
    Posted by Jason Brown on October 16, 2016 at 10:39 pm
    I have some animated text that in Motion 5 that when I export the text looks garbled. Some info that I hope helps:
    1. The “Path Shape” is set to “geometry” and follows the circle in the image.
    2. There are 4 image mask on the circle.
    3. There is a Disk Warp filter that animates through the image as the video goes.
    4. I render it with Color set to color + Alpha with Premultiply checked.
    4a. I’ve tried different codecs.
    4b. I’ve also tried publishing it to FCPX.
    Here is an image of what I get. The 1st is what I see in Motion, the 2nd is what I get after export. Thank you, any help would be greatly appreciated.
    Jason Brown replied 9 years, 10 months ago 2 Members · 2 Replies
  • Robin S. kurz
    October 17, 2016 at 8:07 am
    You might consider posting that here: https://www.facebook.com/groups/apple.motion/ , possibly even along with the actual file. At least I for one couldn’t give you a useful explanation without actually seeing the project. I could only suspect that it may have something to do with the font.
    – RK
    ____________________________________________________
    Deutsch? Hier gibt es ein umfassendes FCP X Training für dich!
  • Jason Brown
    October 17, 2016 at 2:29 pm
    Thank you for the info RK. I will definitely check the site out, hopefully they have some info.
