Activity Forums Apple Motion text export to FCP
  • text export to FCP
    Posted by Patrick Paulson on February 24, 2011 at 4:08 pm
    I have created text in Motion (color w a grey drop shadow). I have selected “alpha+color” for the export.
    Back ground is “transparent” in my canvas. When I bring it in to FCP and try to super it over my video on track one, I get my text with a solid black backround…no superimpose. What am I missing here?
    Thanks for your help.
    Patrick
    Patrick Paulson replied 15 years, 7 months ago 4 Members · 10 Replies
  • 10 Replies
  • Stephen Smith
    February 24, 2011 at 4:13 pm
    Make sure in Motion you don’t have a solid background. To do this go up to Edit, Project Properties. Change the Background option to “Transparent”.
    Stephen Smith
    Utah Video Productions
    Check out my Motion Tutorials
  • Patrick Paulson
    February 24, 2011 at 4:22 pm
    background is transparent
  • Dave Davin
    February 24, 2011 at 4:27 pm
    Hey Patrick
    You could just save the Motion project and import the motion file into FCP without exporting it.
    That should work.
    Dave
    Dave Davin
    Creative Director
    RAIC Productions
    http://www.raicproductions.com
  • Patrick Paulson
    February 24, 2011 at 4:33 pm
    Hi Dave, thanks for the response. I want to have control of my video and text (gfx) independent of each other (video on track one gfx on track two). If I “round trip” it from FCP to MOTN then what I get is my text and video together on one channel.
    When I export and select only “alpha” instead of “color+alpha” I get my text and my shadow, of course I no longer have the color, just white text and white shadow. I can’t figure out why it’s not sending me my color text with the shadow in a format that will super right over the video channel when I select “color+alpha”.
  • Stephen Smith
    February 24, 2011 at 4:37 pm
    If you want to Export it out Set It to QuickTime’s Animation codec. Make sure it is set to Millions Color +. The plus stands for the transparency you want. You can also use ProRes 4444. Best of luck and hope this helps.
    Stephen Smith
  • Patrick Paulson
    February 24, 2011 at 4:39 pm
    I’ll give that I try…heading out now, but as soon as I get back. I’ll let you know how that works.
  • Stephen Smith
    February 24, 2011 at 4:40 pm
    Sounds great.
    Stephen Smith
  • Jeff Greenberg
    February 24, 2011 at 5:01 pm
    Likely your export isn’t sending out the alpha channel.
    Millions of Colors + (The plus is what we need).
    Animation or ProRes 4444 codecs. Nothing else.
    Best,
    Jeff G
    Apple Master Trainer
    Avid Cert. Instructor DS/MC
    Avid & Color Videos Vasst.com
    Compressor Essentials Lynda.com
  • Patrick Paulson
    February 24, 2011 at 9:07 pm
    Thanks Jeff,
    Both Animation and 4444 work as expected. I was trying to export in Pro Res 422 (timeline setting) and no luck…Now I know. Thank you.
  • Patrick Paulson
    February 24, 2011 at 9:08 pm
    Thanks Stephen! That works. Jeff also pointed out that Pro Res 4444 will work and it did.
    Thanks again.
