Activity › Forums › Adobe After Effects › Text Entering Technique
  • Kevin Camp
    December 18, 2013 at 8:25 pm
    with a text layers you can also use linear wipe to create the matte…
    text layers are a bit of an anomaly in ae, in that regardless of size or position, ae always sees them as the size of the comp. that means linear wipe’s completion percentage is relative to the comp, and when you move the text layer, it is independent of the wipe completion, thus effectively masking the text layer..
    it works the same as using a track matte, it’s just another method to accomplish a similar effect.
    Kevin Camp
    Senior Designer
    KCPQ, KMYQ & KRCW
  • Brandon Adam
    December 18, 2013 at 8:56 pm
    Thank you both guys! Both techniques worked like a charm.
  • Ayaz Muhammad hanif
    December 25, 2013 at 8:20 am
    I also want to know that how we can use any script in AE for e.g I want to use ease and wizz script and also can someone tell me that in which language AE scripts are coding???
