Activity Forums Adobe After Effects Text effect and keyframe question
  • Text effect and keyframe question
    Posted by Elorah on August 19, 2006 at 9:30 pm
    I’m trying to use the Fill Color Wipe text preset to animate a phrase. The phrase has 3 lines but I just used one text box. I don’t want to have to split the phrase into 3 different layers to animate it. Is there a way to keyframe it so that it animates at the pace I need it to rather than at a set constant rate?
    Elorah replied 20 years ago 2 Members · 3 Replies
  • Mike Clasby
    August 20, 2006 at 1:17 am
    Yep, you can control it. Just select the text layer and hit “U”. This reveals any keyframes in the layer. Drag the furthest keyframe toward the beginning to quicken the Color Wipe or drag it toward the end to lengthen the color wipe. You can even stop the animation at the end of a phrase if you like, just go to that spot, check the “keys” checkbox, that sets a keyframe there then change the keyframe to a hold keyframe. Frozen. Go down the line check again, to get a newa new keyframe (probably a another hold), change it to Linear (select, Animation>Keyframe Interpolation and you get a box to decide they type of keyframe you want).
    Or if you want to animate different phrases at different rates, from the beginning, set keys again at the spots you want rate changes, then just drag the keys around to get the speed of change you want, closer = faster, farther apart = slow, so you could have the first phrase slow (closer frames), second fast (father apart) and thrid slow again, if you want.
  • Elorah
    August 24, 2006 at 2:29 am
    Thanks. That at least gives me a place to start. But tell me something, I didn’t know what a ‘hold keyframe’ was so I tried to search for it in the Help, but didn’t find anything on it. What’s up with that? This program is so complex and mult-layered I feel like I’ll never figure it out. Plus, there seems to be all these elements that are hidden that AE doesn’t even tell you about.
  • Elorah
