Activity › Forums › Adobe After Effects › Text Default Anchor Point
  • Text Default Anchor Point
    Posted by Planta John robert on June 20, 2011 at 6:00 pm
    Recently, everytime I create a new Text in AE the Anchor Point (0,0) defaults at the bottom of the text when it used to do it at the center. I totally forgot which menu I changed this in before. Appreciate the help!
    Neil Dempster replied 14 years, 11 months ago 2 Members · 4 Replies
  • Planta John robert
    June 20, 2011 at 6:09 pm
    Thanks Dave. However, I was looking for the option to set the Vertical Alignment of the text relative to it’s anchor point and I could only find Horizontal Alignments in the Paragraph Panel (Left, Right, Center). I’m on CS4.
    June 20, 2011 at 6:10 pm
    Thanks Dave. However, the paragraph panel only shows options for Horizontal Alignments and not the Vertical Alignments for the Text.
    June 20, 2011 at 8:20 pm
    Thanks Dave. I was able to find my fix. It was to set the Baseline in the Character Panel. With this, everytime I create a text of the same size, the anchor point is automatically at the center.
  • Neil Dempster
    October 14, 2011 at 1:47 pm
    Hello! When you communicated your fix for this problem, you didn’t mention what setting you used to “set” the baseline to ensure that the anchor point is vertically centered. I assumed ‘0’ would be the correct setting but my text layer is doing what you originally described (anchor point defaults to bottom) and my Baseline is (and already was) set at ‘0’. Could you please elaborate? I have tried everything I can think of to get the default back to what Adobe says is normal (center, center) but to no avail.
    Any help will be greatly appreciated. Thanks!
