Text Counter Connected to Layers Z-Rotation
I’m trying to build an analog meter with a digital text readout. Basically, I need the the source text to read out the rotational value of another layer. As you can see in the image, I want it to be able to read 0 when the needle is at 0, 1 when the needle is at 1 and so on and so forth.
All help is much appreciated!
