Activity Forums Adobe After Effects Expressions Text Contained Within String
  • Text Contained Within String
    Posted by Mike LeBel on August 18, 2020 at 7:13 am
    I’d like to write an IF statement that can look at text in a string (MyString) to determine if a word is contained or found within the string.
    Below is the simplest example I could make up on this question. I know this won’t work but I’m trying to figure out the language.
    Is it possible to search for text within it?
    Thanks.
    MyString = "This is my text"
    if (MyString.contains("my") "Yes" else "Nope"
    Andrei Popa replied 6 years ago 3 Members · 5 Replies
  • Scott Mcgee
    August 18, 2020 at 8:08 am
    MyString = “This is my text”
    if (MyString.indexOf(“my”)) “Yes” else “Nope”
    You were missing a closing bracket, but you use indexOf() not contains. Unless someone corrects me. Eitherway the above will work for you.
  • Andrei Popa
    August 18, 2020 at 8:16 am
    Here to correct and annoy people ?
    In case indexOf() does not find a value, it returns -1. -1 is truthy, so this always returns Yes.
    In case he intends to use this in the new expression engine, else does not work on the same line with if.
    if (MyString.indexOf("my")!=-1) "Yes"
    else "Nope"
    Andrei
    My Envato portfolio.
  • Scott Mcgee
    August 18, 2020 at 12:01 pm
    Ah yes, my bad. Can’t believe I missed that bit. Hahaha
  • Mike LeBel
    August 18, 2020 at 2:11 pm
    This was all super helpful. I’m also beginning to understand more how to search for things and key words on creative cow. Thank you!!
  • Andrei Popa
    August 18, 2020 at 2:55 pm
    About searching things better. Here is what I suggest:
    You need to learn few keywords like string, number, array.
    Then search what you want to find out with javascript.
    For example, searching “find a word in string javascript” returns 2 results from w3schools which both could of helped you ;D
    Andrei
