Activity Forums Adobe After Effects Text Character Different Color – How ??
  • Text Character Different Color – How ??
    Posted by Henry Panniell on October 13, 2011 at 9:59 pm
    I have CS 3 and use Premier and Encore 100% of the time, now i have an ideal that i want to create animated text in AE and have each letter a different color. I can do it in Premier text tool, but Premier is limited in the animation dept. So, (A) I need to make is letter a different color, and (B) Export in into Premier.
    I am all ears, I have been watching various “Basic Text Tutorial” for AE, but nothing takes me to where I want to go.
    Novice Thanks-hap
    Asus PC-DL Deluxe, dual3.2 Xeon, ATI Sapphire 9600 Atlantis, onboard sound
    Henry Panniell replied 14 years, 11 months ago 2 Members · 2 Replies
  • John Cuevas
    October 14, 2011 at 1:04 pm
    Create your a new comp in AE select the text tool and type in your text. With the character window open, select one letter of text and change the color. Save your project
    In Premiere(don’t use premiere often) I think you can now just import the AE composition and place it into your project…and if you want to change your colors, you can change them in AE and it will update in Premiere
    Johnny Cuevas, Editor
  • Henry Panniell
    October 15, 2011 at 1:48 am
    Thanks for the reply, one problem I was having, AE by default is making my text to large and it would select more than on letter. I have to see how to change that, sure its simple enough, and Thanks again for the help. Hope when i finish this project I can spend some quality time with AE.
    hap
