Activity › Forums › Apple Final Cut Pro Legacy › Text changes size when I compress
  • Text changes size when I compress
    Posted by Dan Herz on September 12, 2011 at 4:00 pm
    I am editing a 720p project in FCP (960×720). I am adding lower third graphics to ID people being interviewed. When I compress in Compressor, the video looks great, the lower third grapic looks great, but the text, which I created in FCP, changes in size and seemingly, aspect ratio…and does not fit in the lower third graphic. I do not see anywhere to adjust the text graphic aspect ratio in FCP…and I have never had this happen before. I have tried several times wwith the same result. I am not sure if this is something I need to fix in FCP or in Compressor. Any ideas?
    Dan Herz replied 15 years ago 2 Members · 2 Replies
  • David Roth weiss
    September 12, 2011 at 8:43 pm
    Try exporting as a self contained QT first using Export>>Quicktime Movie, then use that file in Compressor as your “master” to make whatever additional encodes you require.
    Good luck…
    David Roth Weiss
    Director/Editor/Colorist
    David Weiss Productions, Inc.
    Los Angeles
    https://www.drwfilms.com
    Don’t miss my new Creative Cow Podcast: Producing Episodic TV with “24” Producer Michael Klick:
    https://library.creativecow.net/weiss_roth_david/Podcast-Series-1_Michael-Klick/1
    Creative COW contributing editor and a forum host of the Business & Marketing and Apple Final Cut Pro forums.
  • Dan Herz
    September 12, 2011 at 11:33 pm
    That worked…thanks!
    Strange that you have to do that to make it all work.
