Activity › Forums › Apple Final Cut Pro Legacy › Text causing footage to jump/skip/hiccup
  • Text causing footage to jump/skip/hiccup
    Posted by Joy E reed on August 17, 2010 at 9:33 pm
    Hello, All!
    I’ve got a bit of a quandry I’m hoping you can help me with.
    I’m working on an HD sequence, 960X720 16:9, DVCPRO HD 720p60.
    When I add text – a simple line of text, no motion – to my sequence, it causes the video underneath it to jump. The best way I can describe it is that it’s as if a DJ was using a turntable to replay the first couple of frames when the text begins, and then it squirts a few frames ahead at the end of the text clip, causing an obvious jump. When I disable the text clips, the video plays normally.
    This happens whether I’m rendering in 8-bit YUV or RGB (8-bit is what I was using, but thought I’d give RGB a try, just in case…) Field dominance is set to none, and it happens whether I’m using High or Dynamic playback.
    I’m working in FCP 5.1.4 on a MacPro 2.66 Dual Core Intel with 8GB RAM.
    Anyone have any thoughts?
    Thanks in advance for your help!
    Peace & respect,
    Joy E. Reed
    http://www.ohmyproductions.net
    Dave Misener replied 14 years, 10 months ago 6 Members · 8 Replies
  • 8 Replies
  • Richard Harrington
    August 17, 2010 at 10:41 pm
    DO NOT just start changing render settings. Make sure sequ
    Ence setup matches footage. Use easy setup. Then render when you add graphics
    Richard M. Harrington, PMP
    Author: From Still to Motion, Video Made on a Mac, Photoshop for Video, Understanding Adobe Photoshop, Final Cut Studio On the Spot and Motion Graphics with Adobe Creative Suite 5 Studio Techniques
  • Joy E reed
    August 17, 2010 at 10:52 pm
    Sorry–let me be clear. The footage settings match the sequence settings and I’ve been working with this footage for a couple of months –it’s a documentary–but this is the first time I’ve had this trouble.
    When I experimented with changing the render settings, I made a new sequence, changed the settings, and pasted the footage in from the old one.
    Peace & respect,
    Joy E. Reed
  • Chris Tompkins
    August 18, 2010 at 11:54 am
    If the text isn’t Fully rendered it will be jittery on playback sometimes. Does it have a Green bar above it?
    Chris Tompkins
    Video Atlanta
  • John Fishback
    August 18, 2010 at 2:17 pm
    Kave you trashed prefs & repaired permissions?
    John
    MacPro 8-core 2.8GHz 8 GB RAM OS 10.5.8 QT7.6.4 Kona 3 Dual Cinema 23 ATI Radeon HD 3870, 24″ TV-Logic Monitor, ATTO ExpressSAS R380 RAID Adapter, PDE enclosure with 8-drive 6TB RAID 5
    FCS 3 (FCP 7.0.2, Motion 4.0.2, Comp 3.5.2, DVDSP 4.2.2, Color 1.5.2)
  • Joy E reed
    August 18, 2010 at 2:50 pm
    Hey, All,
    Thanks for chiming in!
    Yep, I’ve rebooted, trashed the prefs, repaired permissions, and double checked that all the colors are checked under SEQUENCE>RENDER ALL. Only blue bars at the top of the sequence. I’ve even used render manager to trash the render files for this sequence & rerendered, and the footage is still awonk. 😛
    Peace & respect,
    Joy E. Reed
  • Scott Grubisich
    March 25, 2011 at 11:44 pm
    Joy-
    I am having the exact same trouble in FCE. Did you ever find the solution to this problem?
  • Joy E reed
    March 26, 2011 at 12:25 pm
    Sorry, Scott. Never was able to fix it.
    Peace & respect,
    Joy E. Reed
  • Dave Misener
    November 26, 2011 at 4:40 am
    Hey. This is a fairly old post I’m responding to, but I’ve just been having similar issues with text causing the video to get jumpy. Couldn’t find a solution…but realized that it doesn’t affect the final exported video. Did a couple of test exports and they were absolutely fine.
