Activity Forums Adobe After Effects text around an object problem…. is the only solution a 3d software ???
  • text around an object problem…. is the only solution a 3d software ???
    Posted by Aroonzfx on July 24, 2005 at 7:01 pm
    hi all
    i am having problems with text rotating around the statue..
    i hav the statue modelled in max… which is quite heavy in terms of mesh size… i hav to make the text rotate around the statue .. the thing is I cannot include much text in the same max file as the system is continously getting hanged (only 512 Mb RAM)…
    so when i add the text and extrude it .. the system hangs…..
    so waht is the way in which i can add 2d text rotate around the statue,.,.
    i tried cylinder.. but text comes in front of the statue.. i tried spitting the layer into 2 and the layer stack orders
    but not quite working
    still some text appears in front ..
    how to solve it ??? pzl help
    arun_p_g@rediffmail.com
    thanx in advance
    aroonz
    can anyone spot it out for me ??
    any tutorials in this regard may be helpful
    Aroonzfx replied 21 years, 1 month ago 2,682 Members · 1 Reply
  • Aroonzfx
    July 24, 2005 at 8:01 pm
    i think could solve it ..
    hurrrrrrrrrrayyyy..sorry for such a post
    my new doubt is that if it is text ,,, then no problem for that ..
    but i hav a movie of streaks or say glow moving in an arc shape .. how could i get that to start frm the back and then pass thru to the front ????
    i think i should use warp tools right ???
    plz check ..
    aroonz
