Activity Forums Adobe After Effects Text appearing one letter at a time
  • Text appearing one letter at a time
    Posted by Kathyj on September 8, 2006 at 1:18 am
    Very new to this. I want the text (Her Story) to appear one letter at a time. I want to use this for a Premere Pro project.
    Second question; assuming I do finally figure out how to do this…should I export it to PP or import the project into AE?
    Kathyj replied 20 years ago 2 Members · 2 Replies
  • Graham Quince
    September 8, 2006 at 8:29 am
    Use the text pre-set gallery in After Effects to pick a text pre-set you like, there’s several that do this effect you’re after. (I think it’s in the help section???)
    Then I’d be most tempted to export the effect to premiere and export from that. Because the effect is so short, I’d just export without any compression. It’ll make a huge file, but you won’t have to start fiddling on with different lossless codecs.
    Graham
    https://www.quinceweb.com – web design
    https://www.shiveringcactus.bravehost.com – Free FX for amateur films
  • Kathyj
    September 8, 2006 at 1:27 pm
    Oh thank you Graham!
