Activity › Forums › Adobe After Effects › Text Animators; add a second animation to a character?
  • Text Animators; add a second animation to a character?
    Posted by Jimmy Runsteen on October 6, 2014 at 2:50 pm
    Hi.
    I did a simple animation using text animators with the first character in a word falling from the top of the screen to the middle and then stop. Then the second character falls down and so on. Very basic stuff.
    Is it possible to add a second animation to the character using text animators? After the character had finished its animation and stopped in the middle of the screen i want to add a scale animation to create a sort of bouncing effect.
    The same effect should be applied to all the characters.
    Is this possible using only text animators?
    Roland R. kahlenberg replied 11 years, 12 months ago 3 Members · 2 Replies
  • Engin Osmanovski
    October 6, 2014 at 3:46 pm
    If i am not getting it wrong, it is possible. Just add a Scale animator by using the “Add” menu. Create your animation the same way and adjust the timing of the keyframes so that the Scale animation starts and end after the Position animation.
  • Roland R. kahlenberg
    October 6, 2014 at 11:41 pm
    I’m going to shamelessly plug my product, TypeGEMs, which will allow you to animate text easily in AE.
    Here’s the intro video – https://vimeo.com/104091681
    Here are the presets (more will be added in a couple of weeks) that ship with TypeGEMs – https://vimeo.com/102112250
    And if you want to work with AE’s ray-tracing engine to create 3D Text animations, there’s TypeGEMsRT – https://vimeo.com/104906447
    Cheers
    – Roland
    TypeGEMs – the Definitive Type Gizmo for AE
    https://broadcastgems.com/typegems/
    Intensive mocha & AE Training in Singapore and Other Dangerous Locations
    Adobe After Effects CC ACE/ACI
    Imagineer Systems (mocha) Certified Instructor
    https://www.broadcastgems.com/mographintensity_shapestext/
    This happens because the functionality/content marked as “Vimeo framework” uses cookies that you choosed to keep disabled. In order to view this content or use this functionality, please enable cookies: click here to open your cookie preferences.
