Activity Forums Adobe After Effects Text animation preset – cannot make it do same with right to left
  • Text animation preset – cannot make it do same with right to left
    Posted by Craig Hirshberg on June 4, 2008 at 8:04 pm
    I’m having trouble with the text animator preset “character shuffle in.” Actually, shuffling in from the left works just fine and looks just the way the preset shows it in the browser in Bridge.
    But I also want to use it in the exact same way, except I want it to shuffle in from the left. I’ve tried tweeking offsets, start and end ranges, etc, but the best I can do is make it just shuffle in from the left, but without the last letter crossing the first, and so on…
    Isn’t there a way to fairly simply just reverse what’s going on in the preset?
    Craig
    Craig Hirshberg replied 17 years, 11 months ago 3 Members · 4 Replies
  • Darby Edelen
    June 4, 2008 at 9:04 pm
    I’m not entirely sure how you want your text to behave. Try changing the ‘Amount’ property in the Advanced section of the preset’s Range Selector from -63% to 63% (or some other positive value). Is that what you wanted?
    Darby Edelen
    Lead Designer
    Left Coast Digital
    Santa Cruz, CA
  • Kevin Camp
    June 4, 2008 at 9:11 pm
    you need to set a new position so the characters move from the right of the screen when using the offset parameter…
    twirl down the text layer properties, the the text properties, and then the animator properties. at the bottom should be a position parameter. the default value is something like 1063,0. try setting it to
    -1063,0. if the other parameters have not been changed it should now slide in from the other sid of the screen.
    Kevin Camp
    Senior Designer
    KCPQ, KMYQ & KRCW
  • Darby Edelen
    June 4, 2008 at 9:18 pm
    [Kevin Camp] “the default value is something like 1063,0. try setting it to -1063,0.”
    Just a note, the above should have the exact same affect as reversing the sign on the Selector’s Advanced ‘Amount’ property.
    Darby Edelen
    Lead Designer
    Left Coast Digital
    Santa Cruz, CA
  • Craig Hirshberg
    June 4, 2008 at 10:00 pm
    Thanks everyone! It was a combo of offest and position (within the animator parameters, not transform).
    I also should have just copy/pasted the preset from the text that worked from left to right rather than start with a whole new preset – I think that was messing me up a bit too.
    Craig
