Activity Forums Adobe After Effects Expressions Text Animation following turbulence displace with expression look like Kiel Danger
  • Filip Vandueren
    July 18, 2019 at 11:35 am
    You would need to sampleImage() your noise and use the value as a selector.
    If you don’t really need the actual turbulent noise as a texture somewhere else, this might be faster to do with the noise() function.
    Very close to what Dan did in this old gem of a tutorial:
    https://library.creativecow.net/articles/ebberts_dan/noise.php
  • Paskah Manalu
    July 24, 2019 at 9:14 am
    Thanks for your respond ☺
    But, I have tried. And why the object when I use the expression always outside the area?
