Activity Forums Adobe After Effects Text animation – easing characters into position
  • Text animation – easing characters into position
    Posted by Riccardo Sinti on November 19, 2005 at 4:26 pm
    When animating the position of charcaacters in a line of texthow do I get the characters to ease into their positions?
    If I key frame the end parameter and add an ease in to the end it just eases the last character.
    John Dickinson replied 20 years, 9 months ago 3 Members · 2 Replies
  • Mylenium
    November 19, 2005 at 7:18 pm
    Adjust the text animators under the advanced section. There’s controls for ease there.
    Mylenium
    [Pour Myl
  • John Dickinson
    November 20, 2005 at 12:35 am
    Under the Advanced settings try the RAMP UP setting and rather than animating the START or END parameters for the RANGE SELECT use OFFSET instead. This will give you a smooth transition between the starting and ending values of your choosen Animator Property (in your case, Position).
    best,
    JD
    (Back from vacation in Tokyo)
    John Dickinson
    Motionworks
    https://www.motionworks.com.au
