Activity Forums Adobe After Effects text along a PATH
  • text along a PATH
    Posted by Andehlu on May 29, 2005 at 9:43 pm
    Hey all.
    I am having troble animating text along a path. Is there any chance anyone can talk me thru this? Im using a demo of 6.5 I have got my line of text on the mask line…. but now i have no idea how to make it move. If someone could whip up a quick file as an example it would be much appreciated
    barry @ enterthechapel dot com
    Andehlu replied 21 years, 4 months ago 3 Members · 5 Replies
  • John Dickinson
    May 29, 2005 at 11:05 pm
    Twirl down the text layer and you’ll see Path Options. Use the First Margin or Last Margin parameters to move the text. You might try looking at the Help menu also 😉
    John Dickinson
    Motionworks
    https://www.motionworks.com.au
  • Yoondo
    May 30, 2005 at 6:28 am
    You will need to draw a path with the mask tool then go into the text path options and
    select the mask for the path then do as John suggested.
    I think John forgot to mention that on his post.
    Good luck
  • John Dickinson
    May 30, 2005 at 7:03 am
    Didn’t forget. Andeluh’s post mentions that he already has his text on a path 🙂
    John Dickinson
    Motionworks
  • Yoondo
    May 30, 2005 at 8:20 am
    Oops, sorry about that, John. I forgot to read it myself.
  • Andehlu
    May 30, 2005 at 2:47 pm
    thanks for the feedback guys…..i actually got it working. This was my first time using After Effects. Im a flash designer and had a project that had text along a path, flash sucks at text along a path…After Effects saved my life…… My impression of After Effects is that the interface really needs some work but it looks quite powerful…. I think Im gonna play some more with it 😉
