Activity › Forums › VEGAS Pro › testing read and write speed on drive
  • testing read and write speed on drive
    Posted by Don Cobble on November 22, 2011 at 5:47 am
    I have the Black Magic Disk Speed tester. I have noticed that my external drives sometimes to read and write 100+mbs 5GB stream then after time they slow down to to like 13 mbs? even empty? can you have to many Esatas going at one time?
    they are Esata 1 TB Seagate 32mb Cache
    Is there a multiplier setting I need to adjust?
    PC
    I7 2.8 Ghz 8GB Ram
    Win 7 Pro 64bit OS
    PNY Quadro 4000
    3-4 TB HD
    Vegas 10 64bit & Vegas 11 64Bit & Adobe Production Premium CS5.5
    Camera
    Sony EX1 shoot in 1920×1080 30P
    Nigel O’neill replied 14 years, 10 months ago 2 Members · 1 Reply
  • Nigel O’neill
    November 22, 2011 at 12:12 pm
    I would check your write caching policy is Enabled in Device Manager for the device in question, accessible through the Properties > General click Change Settings button.
    You might also check if your eSATA port is SATA I, II or III capable, with III being the fastest at a theoretical maximum of 6 Gbps.
    From memory I get close to 30 mbps but I cannot confirm as my system is getting repaired.
    My system specs: Intel i7 970, 12GB RAM, ASUS P6T, Vegas Pro 10e (x32/x64), Windows 7 x64 Ultimate, Vegas Production Assistant 1.0, VASST Ultimate S Pro 4.1, Neat Video Pro 2.6
