Activity Forums VEGAS Pro Test Sony Vegas: rendering i7-4790, GTX-580, Quick Sync
  • Test Sony Vegas: rendering i7-4790, GTX-580, Quick Sync
    Posted by Mariusz Kwiatkowski on March 24, 2016 at 9:28 am
    hi,
    I bought used graphics card “MSI GTX 580 Twin Frozr III PE OC 1536MB”, to speed preview and render in sony Vegas.
    After first tests the results was not satisfacted.
    I’ve decided to do some rendering tests with 3 different version of Sony Vegas, with the same entry file, the same project and
    render settings and the same result file.
    Results below:
    Entry file: *.mts, 1080-50i, AVCHD, 60second (without FX) (Sony AX2000)
    Project settings:
    HD 1080-50i (1920×1080; 25,000 fps),
    Field order: Upper field first,
    pixel format 8bit,
    Full-resolution rendering quality: Best
    Render settings:
    Sony AVC/MVC (*.mp4; *.m2ts; *.avc)
    Template: AVCHD 1920×1080-50i
    Bitrate:16Mbps
    Hardware:
    Processor: i7-4790
    mainboard: ASROCK B85M Pro3
    RAM: 12Gb DDR3 (2x4Gb 1600 CL9, 2x2Gb 1600 CL7)
    HDD: SSD 250GB (only system and Sony Vegas), 2x750GB 7200obr. (dane)
    Graphics card 1: MSI GTX 580 Twin Frozr III PE OC 1536MB (driver: 296.10)
    Graphics card 1: HD4600 (intergated with processor)
    Power supple: Chieftec (CFT-600-14CS) 600W
    System: Windows 7 Home Premium 64bit, SP1
    Sony Vegas Pro 10 (oryginal)
    i7-4790: 163 sec.
    i7-4790+GTX580: 131 sec.
    i7-4790+Intel Quick Sync Video, HD4600: no support
    Sony Vegas Pro 12 (trial)
    i7-4790: 82 sec.
    i7-4790+GTX580: 68 sec.
    i7-4790+Intel Quick Sync Video, HD4600: 33 sec.
    Sony Vegas Pro 13 (trial)
    i7-4790: 92 sec.
    i7-4790+GTX580: 74 sec.
    i7-4790+Intel Quick Sync Video, HD4600: 46 sec.
    In render GTX580 was used about 20-30%
    Conclusion is one.
    The fastest rendering was in Sony Vegas Pro 12 with card graphic integrated with processor with IntelQuick Sync (33 seconds).
    The questions:
    1) Anybody have the same configuration and the results are better then my results (with GTX)?
    2) Is my card efficient in 100%? I try changes drivers (on CD with card; latest from nvidia site; ), and the results are worst.
    With driver version 359.06 the results is difference about 2-3 seconds
    3) In this case, processor is strong enough, that any graphics card 5xx series can’t match them?
    After tests I installed Cuda Toolkit 7.5 too. Improvement is only in preview (Best-Full – fluently preview 25fps). Without Cuda
    Toolkit the preview was lag in transitions (even with gpu transition – 10-15 fps)
    Maybe other observations?
    Thanks for answer
    Mariusz Kwiatkowski replied 10 years, 5 months ago 1 Member · 0 Replies
  • 0 Replies
