Activity Forums Adobe Encore DVD test Blu Ray iso
  • test Blu Ray iso
    Posted by Ryan Aquino on February 10, 2009 at 4:27 pm
    I have Encore CS4.
    I created a 10 GB iso file from my project, and I need to mount and test the iso before I burn the disc.
    I’m using Daemon Tools to mount the iso, but can’t get anything to play it. Also when I look at the disc in windows explorer, it says it’s corrupt and can’t read the disc.
    But when I run Roxio’s drive info, it does see the virtual disc, as a blu ray 10 GB.
    Anybody know how I can test an iso disc??
    Additional Info:
    –I don’t have a blu ray burner in the computer, it’s installed in the automated duplicator.
    –Running windows XP.
    Yiannis Valkan replied 17 years, 6 months ago 4 Members · 5 Replies
  • Joe Bowden
    February 10, 2009 at 6:49 pm
    Windows XP doesn’t recognize the file formatting on Blu-ray discs.
    As far as I know, there are no software Blu-ray players that will read BDMV folder that is not written to a Blu-ray disc. Blu-ray licensing is very, very strict.
    There may be freeware that can do it. Check videohelp.com for any tools.
  • Jon Geddes
    February 10, 2009 at 8:00 pm
    Make sure you have the latest version of Daemon Tools. Also, it could be your software player. Like Joe said, XP doesn’t recognize Blu-ray disc format, so trying to view the contents in windows explorer/ My Computer will give you an error.
    I use Power DVD 8, which supports mounted blu-ray images. I believe older versions are not able to play images. As long as your software is up to date and capable of playing Blu-ray, you should have no problems. Your monitor also has to support blu-ray (HDCP compliant).
    Jon Geddes
    Motion Graphics Designer
    http://www.precomposed.com
  • Ryan Aquino
    February 10, 2009 at 8:12 pm
    I think I’ve got this figured out but the trial version for PowerDVD8 doesn’t support Blu-ray playback.
    Is there any trial/freeware that will allow me to test an iso for playback??
  • Joe Bowden
    February 10, 2009 at 8:26 pm
    [Jon Geddes] “I use Power DVD 8, which supports mounted blu-ray images.”
    That is good to know…thanks, Jon!
  • Yiannis Valkan
    February 17, 2009 at 3:03 pm
    You can try Power DVD version 7.2.
    Thats the ONLY version that support playback of BDMV folder.
    Next versions removed that option for the reason Joe mentioned.
    2 minds are better than one.
