Activity Forums Blackmagic Design Teranex 2D sync reference… & Ethernet control???
  • Teranex 2D sync reference… & Ethernet control???
    Posted by Jonathon Lee on October 27, 2012 at 8:52 pm
    Does the Teranex have an internal sync generator? I’m using it via TB to playback a video file @ 29.97 SD and uprez’ng to 23.976 1080p. If I free run the Teranex is it stable? And on the record device, a BMD Decklink HD dual-link, is it sufficient to lock that to input?
    On the original Teranex vc300 you had to use external reference… is this true for the BMD units?
    ALSO… there’s an ethernet port, but it appears to be inactive. The vc300 had a web applet to control the unit. Is there such an implementation on the BMD units?
    thank you!
    Jonathon
    Bob Zelin replied 13 years, 11 months ago 2 Members · 1 Reply
  • Bob Zelin
    October 28, 2012 at 2:02 am
    the ethernet port is not active “yet” – “soon”. Yes, this is very important.
    Bob Zelin
