Activity Forums Apple Final Cut Pro Legacy Temporary Snap
  • Posted by Alan Lacey on October 5, 2005 at 5:57 pm
    I can’t find anything in the manual, but thought I remembered reading somewhere that there is a keypress that temporarily activates snapping in FCP’s timeline. Like the shift click in AE.
    Am I wrong? It sure would be very useful, for me at least.
    Alan
    Alan Lacey replied 20 years, 11 months ago 3 Members · 4 Replies
  • Jeff Carpenter
    October 5, 2005 at 6:44 pm
    I think “n” is what you’re looking for.
  • Jeff Carpenter
    October 5, 2005 at 6:45 pm
    Or not, now that I’ve thought about your question a little more. I see you’re looking for a key to hold. “n” will toggle it on and off, which is close, but not exactly what you meant. I don’t know the answer to your question.
  • Jeremy Garchow
    October 6, 2005 at 3:27 pm
    I think you’re right on Jeff. It works differently in FCP than in AE. In AE it’s a temporary key press and also a temporary ‘state’, in FCP you toggle snapping on and off making it a more permanent state, just as you said. Also, in the upper right corner of your timeline, alan, there’s a little button that will turn snapping on and off. ‘N’ is much easier and faster to use, but the button will show you visually if snapping is on or off.
    G5 Dual 2Ghz <> 4GB RAM <> FCP 5.02 <> Kona 2
    ATTO 42XS <> Huge Systems 1.25 TB 4105 Fibre
  • Alan Lacey
    October 6, 2005 at 5:40 pm
    Yes thanks guys, I knew about the button and the ‘n’ shortcut, It’s just that I’m sure I read sometime that a temp push keyboard button, a la AE was available.
    Thanks for taking the time to respond though.
    Alan
