Activity Forums Zaxwerks Temporary Authorization blues
  • Temporary Authorization blues
    Posted by Rob Womack on July 29, 2008 at 5:08 pm
    I purchased 3D Flag for AE earlier today. I received my temporary authorization code promptly, and after following the installation instructions, I entered the code as prompted.
    When I tried using 3D Flag, I was immediately alerted again that the temporary code was only good for 30 days. Fair enough. However, if I try to render or preview my comp, I am inundated with prompts once again alerting me that i have only 30 days to register my product. I have already applied for a permanent code, but I was under the impression that I can actually use this software for 30 days.
    Each time I try to preview or render, the software puts a prompt behind the UI, and clicking on it does nothing. I have to force quit the software. Has anyone else had this problem? It’s very frustrating.
    Version 1.5.0 on OSX 10.5.4, AE CS3
    Rob Womack replied 18 years ago 1 Member · 1 Reply
  • Rob Womack
    July 29, 2008 at 7:10 pm
    UPDATE
    Heard back from Customer support. Apparently, this happens when your OSX account does not have permission to write to root/Library/Preferences
    They also sent me the Permanent Key, so I haven’t checked this to see if it worked, but I’m puttin’ it out there. the Permanent Key stopped the madness.
    For some reason, the plugin checks for a permanent key frequently. Once a session, or once every 24 hours would seem to be enough, but I guess they’re afraid someone is going to pull something sneaky.
    Robert Womack
    Creative Bridgekeep
    http://www.CurrentMarketing.com
    “Louisville’s Leading Interactive Marketing Agency”
