Activity Forums Apple Final Cut Pro Legacy temporarily disable all filters
  • temporarily disable all filters
    Posted by Agingeri on April 5, 2006 at 7:59 am
    Is there a way to temporarily disable all the filters for all the clips in the timeline, rather than needing to go back and individually disable each filter for each clip? I thought this could be done by unchecking the “Render & Playback > Filters” box under “Sequence > Sequence Settings > Render Control,” but this doesn’t seem to do anything at all.
    Nicholas Bierzonski replied 20 years, 5 months ago 3 Members · 3 Replies
  • Nicholas Bierzonski
    April 5, 2006 at 12:43 pm
    Select your sequence, Apple A , then control click and choose remove attributes…select filters, and you’re done.
    -Nicholas Bierzonski
    Editor/DVD Author/Java Boy
    http://www.finalfocusvideo.com
  • Bouncing Account needs new email address
    April 5, 2006 at 1:05 pm
    [LandofNid] “Select your sequence, Apple A , then control click and choose remove attributes…select filters, and you’re done.”
    WAIT!
    DON’T DO IT.
    That will PERMANENTLY remove all of the filters from the sequence!
    You can UNDO it, but if you forget… they’re gone.
    Now this would be fine if you create a DUPLICATE of the sequence and only remove the filters on the dupe.
    April 6, 2006 at 3:54 pm
    Good point. I should have mentioned that you need to duplicate your sequence
