Activity Forums Apple Final Cut Pro Legacy Tempo Sync or Display Tempo in Final Cut Pro
  • Tempo Sync or Display Tempo in Final Cut Pro
    Posted by Cornelius Henke on July 26, 2009 at 6:22 am
    Is there a way, or a plugin that will analyze a piece of music or audio track and display tempo markers in final cut pro? I have a way around this if someone cannot provide a better answer, but it is time consuming, so I am looking for a better alternative.
    My current solution: Import the song into after effects and use Sound Keys (even the demo works fine for this), find the specific sound that is in sync and link it to a solid layer’s opacity with an expression that limits the opacity to either 0 or 100. Then, export the video file and use it while cutting your sequence into FCP.
    So you can see that this is time consuming and very annoying.
    Thanks for your advice.
    Cornelius Henke replied 17 years, 1 month ago 1 Member · 1 Reply
