Activity Forums Apple Motion Templstes… From Motion ton FCP
  • Templstes… From Motion ton FCP
    Posted by Maxime Belisle on May 16, 2008 at 7:58 pm
    HI,
    I created a template to use as a slate for the different shows of my production company where I work. I created it in Motion so I could modify the fields when it would be loaded in FCP and it works just fine. The fields appear and are modifiable.
    The problem that I have is that the quality of the picture is perfect in Motion but is pixellated and slightly desaturated when the template is loaded in FCP.
    The settings of the Motion project and the FCP sequence are identical:
    DV-NTSC, 720X480, 29,97fps.
    Does anyone knows how I could solve this problem?
    Max
    Noah Kadner replied 18 years, 4 months ago 2 Members · 1 Reply
