Activity Forums Adobe After Effects Temperamental “Advanced Lighting”
  • Temperamental “Advanced Lighting”
    Posted by Laurie Turner on July 24, 2008 at 2:25 pm
    Okay, so I set my settings for the Advance Lighting effect to make a bolt of lighting. I have worked on this project a while with no issues and have rendered it in the render queue with no issues.
    Now after render it becomes a spec or a tangle ball of electricity instead of the bolt. If I go to the settings and play with the conductivity stat then press command z to undo, it returns to a lighting bolt until I render it again. What’s the deal?
    I am using CS3 Pro with a Mac OSX with Intel
    Thanks for your help
    -Laurie
    Laurie Turner replied 18 years, 1 month ago 58,743 Members · 1 Reply
  • Laurie Turner
    July 24, 2008 at 5:07 pm
    Thanks for the club membership!
    I don’t have the setting from the earlier version. What I ended up doing was setting up the lighting they way I wanted, then tweaked a different layer at a differnet part then rended it. It worked for some dumb reason. It rendered the lighting they way I wanted.
    I am glad I am not the only one with this issue. Hi, my name is Laurie and I have issues with Advance Lighting.
