Activity Forums Adobe After Effects Expressions temp inside an expression
  • temp inside an expression
    Posted by Tielman Dewaele on March 18, 2007 at 7:57 pm
    Hello,
    im folowing this tutorial from Mark Coleran(bought).
    Its easty to follow and all :), but when just at the end there go’s something wrong.
    The tut is based like this:
    20 tutorial are parent with NULL01, who is parent on a MASTERNULL01.
    I have 1 CONTROLLER, with 2 control sliders, 1 is for Time, the other for amount:
    T = thisComp.layer(“control(solid)”).effect(“wigg_01_time”)(“Slider”);
    A = thisComp.layer(“control(solid)”).effect(“wigg_01_amount”)(“Slider”)
    wiggle(T,A)
    So far so good…
    Now the NULL01 Rotation i pickwicked it to the R expression see above.
    But the expression gives me:
    temp = thisComp.layer(“Master Null”).transform.orientation[0];
    [temp, temp, temp]
    So i am confused because its not the same in the book : (
    IM a looser in expressions. Im trying realy hard 🙂
    So why does it sais Temp(probebly meaning tempary?), what does it mean?
    Can you help me with this?
    Iff so GREAT!
    T.
    Peace
    Filip Vandueren replied 19 years, 5 months ago 2 Members · 1 Reply
  • Filip Vandueren
    March 18, 2007 at 10:56 pm
    I think you’re pickwhipping from the orientation of Null01 to the first value of the orientation of your master null.
    orientation needs 3 numbers for the three axes of rotation, so After Effects tries to be clever and makes a list of three times the same number.
    Just drag the pickwhip to the word ‘orientation’ on the master null, NOT to any of the 3 numbers next to it.
    That way you’re “copying” the entire list of all rotations.
    The same can happen when you’re pickwhipping towards position-values
