Activity Forums Canon DSLR Cameras Teleconverters and B4 Lenses
  • Teleconverters and B4 Lenses
    Posted by Sejin Kim on February 4, 2017 at 8:22 pm
    NOTE: I’m not sure if this is the right categorization; if it can go in a better one, please tell me.
    I recently acquired a Canon B4 broadcast lens that I would like to use with EF. I removed the servo unit for full manual control. I was originally going to use just a converter from B4 to EF, but came across some discussion about the vignetting, even on APS-C sized sensors. Flange distance isn’t TOO big of a problem since the lens has an adjustable flange distance. If anyone has experience with this conversion (or lens conversion in general), what can I do? What factor of teleconverter would you suggest I use (1.4x or 2x)?
    If this information is pertinent: Canon BCTV Zoom Lens – Model YJ17X9.5B 9.5-162mm 1:1.8
    Blaise Douros replied 9 years, 6 months ago 3 Members · 2 Replies
