Activity Forums Adobe After Effects Teeth Whitening
  • Teeth Whitening
    Posted by Fame Little on December 3, 2007 at 3:41 pm
    Hi All, I have a video clip that has a little yellow in the subject teeth. what would be the best method in removing the yellow & making the teeth white.
    Thanks.
    Fame Little replied 18 years, 9 months ago 3 Members · 3 Replies
  • David Bogie
    December 4, 2007 at 4:26 pm
    Reshoot.
    Or read everything you can on the topic of rotoscoping.
    bogiesan
  • Daniel Dye
    December 5, 2007 at 12:00 am
    You could rotoscope around the teeth, then apply a hue/saturation effect, and desaturate it until it looks good. That will remove the yellow color. If you want the teeth to be whiter, add a levels effect and increase the white value.
    Hope that helps,
    ColdSide Digitsl
  • Fame Little
    December 6, 2007 at 6:34 am
    Thanks Daniel, That works for me.
