Activity › Forums › Adobe After Effects › Technique to remove lens vignetting in a clip with mocha?
  • Technique to remove lens vignetting in a clip with mocha?
    Posted by John Mayer on February 6, 2016 at 2:00 am
    hello,
    I am using mocha to stabilize a shot in a clip, but the lens vignetting as a result is moving around inside the footage. I’m trying to find a way to remove lens vignetting in my footage so I may put an artificial one later that doesn’t move.
    Is that possible?
    Kalleheikki Kannisto replied 10 years, 7 months ago 2 Members · 3 Replies
  • Kalleheikki Kannisto
    February 6, 2016 at 2:50 pm
    Remove the lens vignetting first then stabilize the footage. Then add a new one back in.
  • John Mayer
    February 6, 2016 at 7:27 pm
    Do I need a specific filter to remove the vignette? I know that in Lightroom I can remove it by selecting my lens model and LR will take care of it, but I think it doesn’t work for clips.
    February 7, 2016 at 5:28 pm
    I use curves effect on an adjustment layer with a soft circular mask.
