Activity › Forums › Apple Final Cut Pro Legacy › Tears in Canvas Viewer in FCP 7.
  • Tears in Canvas Viewer in FCP 7.
    Posted by Adam White on January 10, 2010 at 5:26 pm
    Hello,
    Recently I’ve been having an irritating problem with the Canvas Viewer in Final Cut Pro (v.7.0.1). I get constant video tearing in the Canvas Viewer. This occurs when the video is played back on either the main iMac screen, or the additional DVI Monitor. Whilst the footage is still viewable, and the tears don’t render the viewer useless by any stretch, this clearly isn’t correct and can become frustrating when working on scenes with a lot of motion and quick cuts.
    I’ve tried several different playback settings combination’s (Safe RT/Unlimited RT/Different frame rates/scrub high quality e.t.c) but nothing seems to help. Also, video tears only seem to occur in FCP – if viewing a video in QuickTime Player there is no tearing.
    I’m running on;
    iMac 24″ 2.66GHZ Intel Core 2 Duo
    4GB 1067MHZ DDR3 RAM
    nVidia GeForce 9400 256mb
    Does anyone have any suggestions about how I might resolve this? I’m hoping this isn’t a hardware issue!
    Best,
    Adam
    Vince Gooding replied 11 years ago 11 Members · 17 Replies
  • 17 Replies
  • David Bogie
    January 10, 2010 at 7:39 pm
    “Tear” doesn’t help us very much. if you search for the term you’ll see why. You’ll need to tell us exactly what “tear” means to you or, better, post a frame grab.
    On whites? Reds? High or low contrast or every image?
    bogiesan
  • David Roth weiss
    January 10, 2010 at 7:46 pm
    I want to know, are they tears of joy or tears of sorrow?
    David Roth Weiss
    Director/Editor/Colorist
    David Weiss Productions, Inc.
    Los Angeles
    A forum host of Creative COW’s Apple Final Cut Pro, Business & Marketing, Indie Film & Documentary, and Film History & Appreciations forums.
  • Bj Ahlen
    January 10, 2010 at 7:55 pm
    Is it interlaced footage?
    From what source, DV/DV50 or Uncompressed/ProRes? The latter has the opposite field order
    Are you using Easy Setups?
    Just wondering if it could be field reversal from not setting UFF/LFF correctly.
  • Adam White
    January 10, 2010 at 10:21 pm
    Hi David,
    Thanks for your response.
    Here is a simulated example of the kind of video tearing I’m experiencing;
    https://en.wikipedia.org/wiki/File:Tearing_%28simulated%29.jpg
    It occurs most frequently when viewing video with fast motion and/or camera pans or movement. My first thought was that it’s a problem with the refresh rate, but this happens on both the iMac monitor and additional monitor, so I’m not really sure of how to resolve this.
  • Adam White
    January 10, 2010 at 10:23 pm
    Hi B.J.
    One of my first thoughts was that it was an interlacing issue, too. But I’ve tested this on some Progressive material and I still have the same problem.
    I’ve tried DV Pal material with a Lower (Even) field dominance, and HDV 1080i60 footage with an Upper (Odd) dominance and have the same issue with both.
    I’m stumped!
  • Adam White
    January 10, 2010 at 10:24 pm
    They will certainly be tears of sorrow if I have to get hardware repaired! 🙁
    Too much work to do for that!
  • David Roth weiss
    January 10, 2010 at 10:43 pm
    [Adam White] “Here is a simulated example of the kind of video tearing I’m experiencing;
    https://en.wikipedia.org/wiki/File:Tearing_%28simulated%29.jpg “
    That looks like a camera or capture issue to me Adam, almost like a tracking error.
    Is it possible you were dropping frames while capturing?
    Have you played back any material from another project that used to playback properly?
    David Roth Weiss
    Los Angeles
  • Ben Holmes
    January 10, 2010 at 11:29 pm
    Have you tried changing the refresh rate (hz) of your monitor? It sounds like it doesn’t match your video.
    Do you get tearing on an external video monitor? I’m sure you’re aware the canvas is not a full-quality preview, and no good for finishing edits. Have you also checked that you have the frame-rate set to full in the RT settings tabs?
    Edit Out Ltd
    FCP Editor/Trainer/System Consultant
    EVS/VT Supervisor for live broadcast
    RED camera transfer/post
    Independent Director/Producer
    https://www.blackmagic-design.com/casestudies/detail.asp?case=therydercup
  • Adam White
    January 10, 2010 at 11:51 pm
    I’ve tested several different projects, with footage captured from various different sources using different hardware. Some was captured via a Sony Z1, some through a Sony HDV FireWire Deck and there was even some XD-CAM footage that I tried and had the same problem.
    What’s weird is that I’ve just tried a couple sequences again, and the tearing has now stopped. But I haven’t changed any settings either in FCP or System Preferences. I dare say the issue will be back – this has happened before.
    I’m so confused! Been using FCP for about 3 years now, and have never come across this before!
  • Adam White
    January 10, 2010 at 11:56 pm
    Ben,
    Frame-rate is indeed set to full. The refresh rate cannot be changed (it’s at 60hz) on the additional monitor, but as I say the same problem occurs when playing back footage on the iMac monitor. As far as I’m aware there is no way of changing the refresh rate on the iMac – am I wrong about that?
