Activity Forums Adobe After Effects Tear of footage or document?
  • Tear of footage or document?
    Posted by Julia K on May 23, 2006 at 11:28 pm
    I need a quick solution, a producer wants to have video tear in the middle and have $ come out of it… horrid idea but she’s set on it. So my first thought was to create masks and animate the points but it seems too time consuming for something that should only take an hr to create.
    I think i’m mentally protesting from doing this piece and can’t come up with a better solution.
    I would greatly appreciate your response and suggestions!
    Thank you
    Mike Clasby replied 20 years, 3 months ago 2 Members · 1 Reply
  • Mike Clasby
    May 24, 2006 at 4:24 am
    Depending on the tear, you might try CC Split (and maybe rounghen edges on an adjustment layer(above) with a mask to keep the edges to the tear), then use a particle generator for the Money, or use Dan’s 3D Particle Generator, and sub in your photo of money for the sparkle psd he uses in the Fountain Comp.
    https://www.creativecow.net/show.php?page=/articles/ebberts_dan/particle_gen/index.html
    Download his aep for the money sub.
    Or maybe that’s not the look you want.
